The pics are of my head and cylinders. They look pretty good altho a lot of carbon. What is recommended here? New valves as a matter of course or not necessary? Same with piston rings, should they be replaced and cylinder honed or only if there is excessive play? I am going to shot blast the head and block to get rid of dirt
Measure the valve spring seated loads,before you take valves out of the head.Use bathroom scales to measure the spring load.
Take out the valves before you blast the head.I prefer soda blast,but walnut shells should be OK.Don't mix up any springs,collars and valves or collets;make sure you can put them back in the same place if necessary.
Hope you didn't mix up any tappets.If they don't go back in the same position and direction,they need to be re-ground and re-bedded.There is a procedure for this,and slow cranking/idling will cause damage even after the re-grind.
Plug up any threads with old bolts when you blast the head.Make sure to blast the guides clean in the ports.Any carbon here will ruin the head if you need to remove guides.
Measure valve stems and the amount of wear at the top and bottom of guides,then decide what to replace.At 0.008" clearance top or bottom,it's worth replacing guides.
If the guides and valves are good,still do a valve job:cut seats and re-grind valve faces,especially the top of the valve stem.
