1 - 15 of 15 Posts
Vendor
快速换挡应该需要ECU支持的,且需要一个接线的接口。我觉得应该是很难的,除非凯旋预留有接头,且ECU支持。
... or unless the vendor is a clever fellow who can leverage how the ECU works, even though it doesn't have a dedicated QS function! =)
I am looking at Annitori quickshifter product which has more reliability. Unless there is a basic schematic on TTRignition system explaining your product, otherwise how to convince potential customer on your product?
Vendor
Fair point.
The TTR controller briefly interrupts the sidestand signal; the ECU thinks the stand is down, and cuts the engine. There are three wires coming from the controller box - signal, ground, and 12v. I generally prefer to use the existing connectors to tap into the side stand switch (for ground and signal), and the rear brake switch (for 12v). If there is no information available, or the connectors are unobtainable, then the unit is provided with instructions on how to splice into the existing wiring.
Fair point.
Oh,you're a delaer.
How much is it?Applicable to Tiger 800 XCA?
Vendor
US$200 for sensor and controller, +$15 shipping. I did some reading on the XCX and it will work, so it should work with the XCA. This will be a splice-in model, as I can find no information on the connectors involved.
I would like to take a picture of the side-stand connector for you,tomorrow.
Vendor
Perfect! If you can get a clear close-up of the connector, that would be great.
The connectors are covered with dirt.
I think they are DJ7025F-2.2-21(sensor side) and DJ7025F-2.2-11(main wiring side).
Vendor
Good stuff - those are Sumitomo HM connectors, and readily available at a variety of vendors. Could you clean off the wires at the harness side, and determine which has a green stripe, and which has a red stripe? This will allow me to design the connectors so you simply plug it in between the harness and the sensor.
The engine is still turning, under its own momentum and that of the bike and drive train. The ignition is only killed for ~ 40-60ms, too short for the engine to slow down much. When the ignition is switched back on by the ECU, the engine immediately restarts.
1 - 15 of 15 Posts
