Few quick questions.
I was a space cadet and forgot to have the shop check my bike for recall items when I was there on Saturday, was too busy looking over the 50% off Triumph apparel.
So, is there a link someplace here with a list of all recalls specific to an 03? Advanced search didn't lend much of a hand when searching for "recall"
Tank removal, installed a heat Troller, long story, first time disassembling my bike and a few surprises. When removing the fuel lines, they don't have cut offs? Meaning they are not sealed when the fuel lines are removed? Few other bikes I have worked on had one way check valves when the lines were removed. Fuel spitting from the connectors (2) at the tank and from the bike side (red connector) line. This normal or was there a recall related to this? Rambling on here so you can all laugh at me but thought I read something about it here in all my readings before buying the bike.
Anyways with much thanks to folks (Rich_Williams and others) who I asked questions to installed the heated grips and troller and GOD what a difference. Ran all day today 40 or below with no issues, half the day was spent with thin summer gloves and sub 40 I switched to JR winter gloves. Great stuff.
Troller install was more time consuming than I thought, installing in the left side controls and such. Not entirely happy with the LED placement as I am a bit close to the actual nob. however after finding out that the silly thing blinks when not at the rated temperature I am glad its slightly hidden.
Only point I would like to make on the troller install at this point till I do more of a write up is that I had to defiantly remove one of the wire guards inside the left hand set, and clearance points for the switch knob on the top. Which I hadn't figure on. Other than that I am definitely LOVING the adjustablity, hey is that a word.
Pics to come.
Please bear with me here normally service VW/Audis but have limited knowledge of bikes so learning process for me here.
Triumph Motorcycle Recall
NOTE: These recalls are presented as a public safety resource. For more information, visit your local BMW Motorcycle dealer or visit the National Highway Traffic Safety Administration website.
Triumph Motorcycles (America) Ltd.
Models:
Triumph Daytona 955 Years: 1997-2004
Triumph Daytona T595 Years: 1997-2004
Triumph Speed Triple Years: 1997-2004
Triumph Speed Four Years: 2002-2004
Triumph Sprint RS Years: 2000-2004
Triumph Sprint ST Years: 1999-2004
Triumph Tiger Years: 1999-2004
Triumph TT600 Years: 2000-2003
Triumph Daytona 600 Year: 2004
Number Potentially Involved: 18,998
Dates of Manufacture: June 1996 – September 2003
Defect: On certain motorcycles, the fuel connector linking each of the feed and return fuel hoses to the fuel pump mounting plate may fracture following in-service handling. Fuel could escape from the fractured body of the connector onto the engine or side of the bike. Fuel leakage in the presence of an ignition source could result in a fire.
Remedy: Dealers will replace the connector. The manufacturer has reported that owner notification is expected to begin during May 2004. Owners may contact Triumph at 1-678-854-2010.
[NHTSA Recall No. 04V156]
w00t not loosing my brain!
So its possible I need to get these recalled if they are not already done.
Thanks Limester! :-D
