1 - 13 of 13 Posts
i just got my renthal ultra low bars in and am going
to swap them over today. but the stock bars have holes
in them for the nubs on the handlebar control housings.
do i drill out the renthals or grind off the nubs???
i'm inclined to grind off the nubs but am afraid of the
housings spinning on the handlebars.
how have some of you guys done it? and with what results?
i drilled out the nubs...take and wrap a coupla wraps of tape around the place where the housing goes then it has a little more meat to grab...mine don't move
whoa, it seems to be split down the middle..
grind!......drill!.......grind!.....drill!....
well i decided to play it safe and drill.
will post pics 2morrow (also installed pazzos)
the bike is now starting to look sweeeet!!!!!
my TORS arrived today also so i think i might
just blow off drinkin tonight and jump into
that project!!!!!
On 2007-03-24 18:45, xSpeed3x wrote:
Grind the nubs. I did and they haven't moved in 2 years.
i think our speedys come from the same gene pool
</a>">
Sorry if this is a repeated question (I'm sure it is) What headlight/fairing is that? Will it accommodate the stock instruments?
On 2007-03-24 22:26, xSpeed3x wrote
No your stock speed won't work, I use the Veypor on mine but recently you can them pretty cheap.
ahhhhhh, zip ties *** wouldja do wit out em'
</a>">
+1
Shame cos I switched back to standard shortly after fitting Renthals
MH
Grind the nubs. Renthals specificly advices agains any drilling of the bars to prevent fatigue cracks from starting from the holes.
Have had the Ultra Lows on for 2 years + and the controls have not moved at all.
1 - 13 of 13 Posts
