Hi,
I bought the Pazon electronic ignition system for my '73 T140V Bonneville restoration project. I'm not terribly proficient in electrical systems. I watched the Lowbrow Customs installation video. It was helpful except he was installing on a custom bike with negative ground. I've ordered new 6v coils which I'll wire in series as shown in the wiring diagram below.
My question is, I'm not sure where the White lead from the Pazon module connects. The instruction manual says it installs "to one of the negative ignition feed wires." I don't understand what wire that is. I tried to annotate what I'm dealing with in this picture. I've disconnected the previous point wire leads from the 12V coils which I'm replacing.
Also, can anyone explain what it means at the bottom left of the wiring diagram, ""Ignition coil H.T. leads connect to plugs any way around."
Thanks.
Thanks.
