I notice that some are mounted steeply and some low. Is this just the way you fit it?
Are the baffles fixed or can they be removed?
On the earlier models (up to & including 06 I believe) they had a steeper angle, when Triumph added another cat in the midpipe the new version of the Mivv had a less steep angle.
Also when you buy the pipe you need to ask for the road legal one, then when you get it you can drill out the rivet holding the baffle in (easy) & then take it in & out as you like.
Nice one gaz.
So, mine being the 05 will have the steeper pipe? Do you have the price.
