This has already been done recently do a search but know the AXLJAK Sliders are far superior to the LSL. Cases will not hit and they have ones for the rear shock mounts also. Bad design, the LSL's are bolted directly to the cases which are nothing but pot metal with #6 chrome bolts. They don't protruded enough to provide protection. If you drop it on the case your going to do damage to the bolt mounting points. The AXLJAK units are bolted directly to the frame at the strongest point on the bike. They are far better made and much stronger. I run them on my Thruxton as do 90% of the Transatlantic Challenge Competitors. If you want maximum protection, then you should go with the AXLJAK Units. Hope that helps in your decision.
Cheers
Jeff:motorbike2:
