I'm strongly considering trading up to a 2010-2011 Thunderbird. I'd like to get some user feedback on the bike. I've taken it for a couple of test drives and really like the bike, so it's probably just a matter of time. If you can help me with any of the below, I'd appreciate it.
How accurate are the gauges (speedo, fuel, odo)? On my current bike, the speedo reads 10% high stock, which translates into the same error on the trip/odo. The fuel gauge is also complete junk, and reads empty at 2/3 tank remaining.
Any option for locked gas cap other than Triumph branded? I find it weird that a locking cap is not standard.
Is there a recommended weight chart for the adjustable shocks? As I don't have the bike, I don't have a owner's manual yet and for some reason Triumph doesn't have them for download on their website that I could see. I've read some reviews saying the #1 setting is too soft and recommend #3 for riders >200 lbs. I've also read people say that #3 was too high for 2 up riding. I'm curious if this is documented in the manual at all, or if it's just trial and error/user preference. I'm about 250, and found the #1 setting on the test bike to be really soft and probably caused the pegs to scrape more than I would like.
Any info on when the 2012 should start appearing at dealerships? I'm currently looking at ~12k USD incl/ $400 in accessories on a 2011 ABS black. Having the leverage of labeling a prior year hold over when 2012s come in couldn't hurt. Also would be nice if the 2011's would get the preferred financing terms as well (cheap financing is only on the 2010s atm).
Can you mount highway pegs on the frame or do you *need* the dresser bars? If you want to add the Triumph pegs, it makes you pick up the dresser bar. Anyone mounted them on the existing black frame bars?
How do people find the stock seat? In my admittedly limited rides, I found the seat to be very comfy. But, I also thought that initially on the Vulcan, which turned out to be terrible after ~30 min. Is there a consensus on the stock seat or best replacement options?
Thanks in advance for reading and comments.
