21 - 21 of 21 Posts
Choke cable hole plugged?
You said your choke is removed?
You made sure to plug up the hole in the top of the carb where the cable went in, right? If not, a big hole there could cause problems.
What color are the spark plugs? They can be lean/rich indicators.
Check out these sites for some Amal carb tuning tips and theory:
http://www.klempfsbritishparts.com/techamal.htm
http://www.jba.bc.ca/Bushmans Carb Tuning.html#REBUILD
http://www.ironcross.net/AMAL.htm
http://www.russianmotorcycles.co.uk/carburettors_and_control_cables.htm
Good luck and have fun! :D
21 - 21 of 21 Posts
