1 - 1 of 1 Posts
I want to paint my tank and started to remove parts off it. No problems with knee pads (I was surprised they are still here- it was so easy), then broke head of one bolt keeping tank badge (that's my problem), then removed both bolts on other side to see construction. After both bolts are removed I can't remove badge and rubber under it! No bolts needed:) But what is the trick? Is it glued (better than knee pads) or rubber stick to metal so good in 10 years?
1 - 1 of 1 Posts
