1 - 1 of 1 Posts
Hello,
I have for some time worries of slow. (Hold it)
I initially try adjusting the stepper motor pas.sans success, not the bike stalled but give jolts a low constant acceleration.
Secondly. I change the setting of the center set screw (the one under the ramp).
And I have further aggravated the situation..elle gives so many jolts it is rideable.
So I you all again remprendre to zero and reset the central screw to its original position, and I thought finding the manipulation in the technical journal .. and I read in the magazine that you should not touch this screw, it is factory set.
Therefore no information on how to put this central bolt in its original position (so with good opening butterfly at rest)
would you information? the way to do?
thank you
1 - 1 of 1 Posts
