i have pro tapers and have used on the speed triple, but removed them because i could not fit my napolean bar end mirrors with them.
They looked cool. I used adapters I got from bajadesigns.com to install in place.
Any dirt bike shop should have it. This was the same setup I had on my xr650r.
the universal risers will need some custom work
you will need to trim them down in height and width
you will need to bore the bolt hole for the factory risers out a bit and either use washers to space the factory recess flush or ger a custom spacer
also new bolts or again washers will be needed on the underside of the top clamp
