1 - 20 of 21 Posts
My order from BC came in today with my new shinny Predator Exhaust. As I was unpacking them I noticed a little black oddly shaped piece . What is this for ? I will post a pic if needed.
could it the stopper for the kick stand? thats the only thing I can think of, but I had to pull it off my old pipes
That metal piece, as Sands stated, is for the kickstand stop. Remove the factory rubber piece and install on the new bracket. Mount it to the bracket hole for the factory centerstand mount and adjust to properly stop the side stand.
hey neighbour!
redrider, I see you are in London - I'm in Waterloo with a recently repaired salvaged '04 red thruxton. I notice that you have done some mods - any parts you want to get rid of?? I'm just starting my mods and we both know the difficulty getting parts in Canada and the expense of ordering from the states! This is just me trolling for some cheaper, close-by parts.
The Mod Illness is a nasty thing !! I will PM you with a few stock & aftermarket items that I my be interesting in selling.
Still need some help
After reading the posts I thought I understood what I needed to do. When I looked at the stock mufflers and compared them to the BC Preds I was more confused than ever ?
The stock left side muffler has a built in bump stop. The Pred dose not .Is this were the little black oddly shaped piece comes into play ?
I also noticed that the mounting holes on the mufflers were not the same ? The stockers are round,and the Preds are well not round ? I figured that I needed to remove the rubber inserts from the stock ones and use them on the Preds ? Not so. *** !!
Have a look at a few pics I took.
The only other question I have is. When you mount the mufflers up to the down pipes do I need to seal/glue them ?
I also noticed that the mounting holes were not the same ? I figured that I needed to remove the rubber inserts from the stock ones and use them on the Preds ? Not so.
Hey Redrider
I faced the same confusion a couple of months back, What I did was mount the supplied bracket off the header-exhaust clamp bolt and used the OEM rubber stopper on it. Obviously you have to do this with the bike on a swing arm stand, but leave the bolt untightened and gently swing the sidestand back and position the stopper bracket where it needs to be then tighten away. Actually you'll find there's more ground clearance than with the original configuration too.
Yes you do need to seal them - I don't recall the name but it's pretty standard stuff in a tube (I know it's mentioned in some earlier threads). Also be careful when putting the chrome trim piece (for want of a better description) back - the 2 tabs slide under the clamp and once positioned to hide the joint properly can be tightened - I say careful because the tabs are very weak and bend easily - so much so that the trim piece on my bike just flew off on the way to work this week!!
Hope this helps - if you need me to take a pic of mine let me know
Cheers
Steve
Discussion Starter #9
"Yes you do need to seal them - I don't recall the name but it's pretty standard stuff in a tube (I know it's mentioned in some earlier threads)."
Would Permatex be it ?
Discussion Starter #14
Would love to hear how the install goes. I just ordered my preds last week and they should be here in a few days!
I am sending my down pipes off to be ceramic coated ,and have 10inchs of snow to deal with right know. Your most likely going to be mounting yours before I do.
Redrider, where'd you end up sending your pipes to be coated? I'm still on the fence whether I just polish 'em up and "learn to love the blue" or shoot 'em out to Jet-Hot, Performance Kote, etc.
Jason
Discussion Starter #16
Jason
I had two local places to choose from for ceramic/powder coatings. I was also on the fence with what I wanted to do with my down pipes.
This the one I ended up going with.
http://www.fireballcoatings.com/
The factory service manual specifies silicone sealant for the muffler/header joint. Any major brand of hi-temp silicone should work; look for it at the your local auto parts store.---James.
I just ordered mufflers and new jets. The airbox will be next. I am in atlanta but from what I've heard lately it is suppose to get very cold here in the next few days. I'll probably wait until the end of March to put them on. This will probably change once there sitting around staring at me in my condo.
This subject has been mentioned in many previous threads but you won't get much performance increase with just the Preds only - it really needs to be done in conjunction with improved airflow to the carbs i.e. if you don't allow more air in, the Preds will only exhaust the same as the standard mufflers with less back pressure and more noise. A lot more, believe me! If you don't improve the airflow in then there's no point in rejetting either. So best bang for the buck either remove or modify the airbox - I did, and it's a huge improvement in performance, sound and fun!:D
1 - 20 of 21 Posts
