I just talked to the guys at Dynojet and they said they don't have any models for 07/08 S3?! So I guess I can't use an older PC3 model on my bike???
I thought you could take any of those fuel/air mappers and just get a custom tune specifically for your own ride?
Kind of... but then you need the right PC3 (& does it adjust timing at all?) so really if it's a truely custom map you're after then you need a Tuneboy set up. To be honest it's beyond me why anyone with an speed triple would actually
want a pc3
The tuneboy set up is miles better and more tuneable and you can
still enter the official Triumph maps
and adjust them to suit. For me it's a no-brainer. I used to have piggy back ecu(just like the pc3) tuning on my car and whilst it was better than nothing it was nowhere near as tuneable(or safe) as the power fc(fully tuneable ecu) I have now. It also only "adjusted" the fueling but not timing too. Piggyback ECU "tuners" are, to be honest, very amature and merely trick the ecu into reading a false airflow & doing something it otherwise wouldn't do whereas the tuneboy actually adjusts your ECU parameters itself and so you dont need to install any hardware at all; in fact no-one need ever know you've adjusted anything as there's nothing tangible to see. You could tear all the cats off your bike and give it any free flowing exhaust you like and then still tune it perfcetly to match the set up.
I would want my fueling and timing to be spot on and give the very best smooth power (regardless of HP) but I have seen alot of people's maps after having factory maps installed or PC3 tuning and frankly some of them are only just safe with regards to fuel curves. Some of that may be due to other EU b.s. fitted but the more adjusting you can do the more of that stuff you can dial out. I don't work for tuneboy btw but I do have both experiences of piggyback fuel tuning and full ECU mapping and they're a world apart. The tuneboy is even cheaper.. go figure.
Sorry for the long post; just trying to help out fellow members and maybe explain a few things from my experience. Hope it helps
