1 - 7 of 7 Posts
Getting them just right is not the easiest thing to do. You may have to loosen one and adjust it a bit to get it right. Scopeit from several angles and sit and try and repeat until your happy with it.
J,thats what you need to do..Just loosen the 2 small allen bolts and rotate the levers to a comfortable position. The two levers do not need to be the same.Just a natural pull position.The levers will move alot further than the control housings because they are farther from the axis.A little twist goes a long way.
I find my right hand throttle sticks if I position it differently;it's close enough though .You can also adjust the distance of the levers from the bars on your T 100 by spinning the dial at the levers fulcrum.
[ This message was edited by: meatwagon on 2006-12-03 23:24 ]
Make sure the throttle isn't binding on the end cap if you move it. Slide it in far enough so there is a small gap.
Also, there is a small marking on the stock handlebars that is used for an alignment/starting point. You can use it for reference.
1 - 7 of 7 Posts
