1 - 8 of 8 Posts
Hello,
I just bought a 02 Daytona. The bike is pretty stock, but the previous owner did swap out the stock turn signals to low profile led ones. I am pretty sure when I picked up the bike that the turn signals worked, but now the right side signals are fine and the left side ones don't blink. Instead the signals stay illuminated and the dash indicator also stays illuminated. There is also a buzzing from the tail section of the bike when the left side signals are on. There is a normal clicking sould of a relay when the right hand signals are on.
Any thoughts?
imarcr2, Unless the led has shorted the most likely cause is the wiring. The buzzing sound is likely the turn signal relay.
Brad
I hate wiring, but I will track it down. Couldn't hear the buzzing when i was actually riding the bike....just the howl of the triple:D
Bill
Bill, Don't worry about the buzzing relay. That'll stop once the trouble is fixed. The problem is most likely just a few inchs inside the fairing.
Brad
Turned out to be the wiring for the aftermarket turn signals. I was very close to getting ribbed from my Japanese bike owning friends for the typical "brit bike with electrical problems....lucas prince of darkness stuff"
Bill
Bill, You can tell your buds that your Triumph has the same Japanese electrics they have. Thanks for reporting the fix.
Brad
Discussion Starter · #8 ·
Brad,
They made the English joke right until they heard that howling triple. Not sure if that shut them up, or if I couldn't hear them over the engine!
1 - 8 of 8 Posts
