1 - 2 of 2 Posts
So late last season I noticed the left most plug wire gasket was loose on my Legend 900. I took the wire out and lo and behold, the plug was loose also. Tightened it up and still, the plug wire pops loose. No sense in repeating. Should I have checked the gap to make sure it was OK? Or is this something more serious than a new set of plugs?
They seem to develop that tendency alright, hard to be sure if the connection to the plug is good or just about ok maybe. If that lead is the same length as one of the others, could try a swap. I fitted a couple of 'pattern' leads from Sprint Manufacturing in UK & they seemed to fit a little better.
1 - 2 of 2 Posts
