does anyone know the easiest way to remove the oil pan off the thruxton? i cracked it after an accident. I drained it and unbloted the pan but its caged in by the frame.....any ideas?thank you.
On 2006-12-12 01:01, rabbid wrote:
On 2006-12-11 16:40, tcb wrote:
You can unbolt the frame lowers easily on these bikes. :-D
would it be best to have the bike raised on the jack?
No because you won't be able to unbolt the lowers because the bike will be sitting on them. A swingarm type lift could hold it up for you though.
