61 - 80 of 80 Posts
Discussion Starter · #61 ·
That suggestion was to hopefully rule out any questionable connections or wire shorts etc . You've kept us all busy trying
to resolve this from afar ! Peter
Also I was hoping you could check the pulse from the CPS to the ignition module ( ecm , etc)
thats what i dont get, i checked the signal coming from the cps at the plug where it plugs into the wiring harness
Discussion Starter · #64 ·
this feels like surrender, but yesterday when i put those new coils on and it didnt work, in the heat (southeastern washington) and frustration and rage, i damn near lost my temper
1998 T595 Daytona 2014 Kawasaki Ninja1000ABS
Very understandable. I know someone who torched his bike. I had similar issues to yours with a 2001 SV650. Cylinder kept cutting out and I went through every system to trouble shoot. Didn't ride at all that summer. Even used an oscilloscope to view the pulses from the signal generator. I finally decided to find a used ignitor and see what happens since you can't test those units. This was in the fall. It worked. That was my issue all along. I replaced parts that didn't need replacing like you. I channeled my anger at the bike and sold to a friend even though it was running great again. I had the bike for nine years so was time to say goodbye. That's when I bought my first Triumph, T595 Daytona. Still have but hasn't been on the road for 6 years. Trying to fix up this summer. Don't give up yet.
Discussion Starter · #66 ·
whew, before i bought a dealertool, or took the bike to get diagnosed, in just read that there is no obd2 diagnosis port on this model bike, so is there no way to troubleshoot the igniter?
'06 Speedmaster
@BigJoe84
The only way I know of to diagnose a bad ignition module is to swap in a known good one. Have you checked for a motorcycle salvage yard in your area that might have one?
'06 Speedmaster
Discussion Starter · #71 ·
@BigJoe84
What happened to the stock one for $150 clams? (Not an issue - just curious!)
Although, you'll likely be happier with the Procom unit since it allows re-maps for future performance upgrades! Praying this solves your gremlins! 🙏🙏🙏
John
i was mistaken, it wasnt for this model bike, google had a spasm i guess
Just to make sure ; this was checked with the plugs in the head and a spare plug in one of the spark plug leads ? Peter
I was truly hoping to have a hallelujah moment here :( .
Discussion Starter · #76 ·
Yes that's how it was tested, I've listed this piece of **** for sale.
I am no expert on the subject, but have been around this forum enough to know that procom igniters are NOT plug and play! Before you ditch the project, give them a call and see what advice they might give you. TTP fire starter would have been a better choice.
Discussion Starter · #80 ·
Have you read the rest of this thread?
61 - 80 of 80 Posts
