1 - 11 of 11 Posts
Lightly used PitBulls for single side swing arm Triumphs, These have the pins for 97~01 Daytonas/T595. May fit other models ,but was used with a '01 Daytona.
$150 for the pair, picked up in either Bristol or Brookfield Connecticut. I'd prefer not to ship at this time.
FYI, my Pitbull rear SSSA stand works with all of my SSSA Triumphs, 1999-2016 in my case.
I have the same hybrid front stand and it works on all my 955i bikes, but not my 2016 1050. Won't work if you swapped out a Hayabusa USD front end, as the hole in the bottom of the steering stem is too small
Sent from my SM-T550 using Tapatalk
@coralkid54, shipping will be around $100 based on box dimensions and weight.
It will be easier and less expensive to sell local. If you're in the area stop by. Or have someone visiting CT/NY in the near future?
1 - 11 of 11 Posts
