1 - 9 of 9 Posts
A while back I think I read that someone fabricated some pieces to lower the pegs on the bonneville. Anyone have any information on this?
I was surprised how much difference in comfort there was when I simply switched footpegs. Carefully remove the "e" clips on each footpeg pivot pin and switch left to right and right to left. Remove curb feelers, and done.
I didn't measure the before and after, but i would guess about 1/2 to 3/4 inch. It is literally a 2 minute job and easy to switch back if you don't like it. I was surprised that such a small change made such a difference. You may need to adjust your shifter height though. Be careful when removing the "e" clip. They are easily bent and ridiculously expensive from Triumph. I am sure there is a cheaper alternative if replacement is needed.
1 - 9 of 9 Posts
