Perverts.
Hello all, once again. I met up with SDFour this Saturday and it was great. Got the keys squared away, as well as a host of documents, manual, and pics of the bike before it's mishap. The pics are what really got me in gear to do some work on Misery III (Emma), not to mention seeing SDFour's other '03 Speed Four intact.
So, here's what happened today:
The fairings have already been removed here, as a result of it falling over and cracking the left side one in half. I should have done that as soon as I brought it home, but I got distracted. Ah well. The snorkels have also been removed.
You can see the side casing has been removed, and has been this way for a few weeks. Also, the headlights have the.....well....headlights pulled, so just the housings are there. Still have to think up something for it.
It looks awful, huh? Underneath that oily mess of shop towels is the stator. I wrapped it in the towels to keep it from scratching up the inside of the alternator. Also, you can see that the bendix for the starter is missing. I just had to keep repeating to myself to make sure I installed it before I put the cover on. If anyone needs to replace the gasket on this side, just realize that the gear may come out with the case cover.
And that's the cover. The new one is on the Right :razz:
And here's a shot with the new cover on.
Man....she's pretty much naked at this point. Guess I work pretty fast
Tank removed to access harness connections, radiator and fan also removed.
Other than that, it was just minor work. I replaced the rear turn signal, replaced the spring for the starter button, mounted the front brake reservoir, removed the footrest brackets, and then just stared at what was left for a moment or couple.
I'm going to just tap and drill in a new bracket on the bottom of the radiator, instead of getting a shop to weld the tab back on. Also am going to a Triumph dealer tomorrow to buy the oil, radiator fluid, ask about ignition parts, and some other things that I seem to be forgetting all of the sudden. I'll keep updating this as time progresses.
[ This message was edited by: doc_rage on 2007-01-07 16:16 ]
