I recently installed the long handled Pazzo race levers on my '05. I really LOVE the feel it gives on the brake lever over stockers, but the clutch lever doesn't activate the clutch in any setting less than full span. Any help?
I put the shorties on and had some clutch adjustment that was needed to get it to work right. I had to get rid of the 1/8" play in the lever that the service manual says to use.
Not to make myself seem like an idiot, but when I first installed my Pazzo's, I forgot to re-use the stock bushing for the clutch lever. It did the exact same thing. I looked at the lever, took it back off, realized my mistake...and it's worked perfectly since then.
Long story short. Make sure to use the bushing, and it should be OK.
Thanks guys! I did use the stock bushing when I installed, but did not take the slack out of the cable. I will try the adjustment later today (once the temperature hits 20 degrees). Thanks again!!
