Just got my Pazzos, brake lever fitted no problem, but hole for pivot bolt in clutch lever is bigger than bolt. Do I need to remove the brass bush from the standard lever or has my supplier sent a dodgy lever? Thanks.
It has been a while since I installed mine, but if memory serves me I used the the sleeve out of the stock ones.
Yep, I've just found an old thread dealing with this very issue. The standard bush needs to be used. Guess I should do a search before posting. Thanks all the same.
