I swapped out the stock levers this morning for a beautiful set of Pazzos, with titanium- colored adjusters Thanks to the knowledge base offerered here, it took all of ten minutes to complete the task! Time for a ride!
denoose
Those guys are good! Delt with a Sean a couple times.I purchased the levers from British Customs, the chap's name is Alex. Great service and speedy delivery!
denoose
British Customs, LLC
310-225-2570 (Phone)
310-225-2580 (Fax)
www.british-customs.com
Typically you can't buy pazzos with any color combination you want, it costs more money to choose non standard color combos. The blue levers with gold adjusters just happen to be a non standard combo, it cost me 6 dollars extra per lever for that particular combination.Kory, what is custom about your particular set?![]()
Sorry to bust your bubble, but you can get any color combo from just about any Pazzo vendor.Typically you can't buy pazzos with any color combination you want, it costs more money to choose non standard color combos. The blue levers with gold adjusters just happen to be a non standard combo, it cost me 6 dollars extra per lever for that particular combination.
Have you ever called EMA OND?
--Kory
That would be the Poor Man's Velocity Maintenance System:
A Caterpillar O-ring, Part number 8M4991, from your local Cat parts distributor. It slips onto the groove between the bar end weight and grip and provides enough friction to function as a cruise control. My local guy sold me 2 for $5, and I've been using the first one for about 3 years.
denoose
