Sooo,
I finally pulled the air restrictor and put in bigger jets. While doing so I absent-mindedly unscrewed the brass fitting the jet screws into and plop! a little brass gizmo comes out with it.
Here's the fun part...which way is rightside up when I put it back?
Thanks in advance.
You'll see the collar has a thicker band on it - but not centered - one side is longer. The longer part of the collar goes into the orifice first. [Did the same thing myself]
Much better, Prop. I looked at my Jenks photo, which is not as clear, but I do recall reading that it will only go in one way.
