Well I am going to paint some letter of the stock tires on my thruxton with a sharpie. Tested on other rubber, seems to work very well for something you can get at home Depot or an arts store. Will post pics later with conclusion.
FWIW: Years ago I did the same thing with white plastic model paint and it worked quite well.
The front tire is a good bit harder to keep in the lines. I had the very thick brush. It works PERFECTLY on the rear tires for it fitting inside the line. It actually fit perfectly between the lines when filling in the rear. Front...was a bit harder.
