1 - 9 of 9 Posts
Recently took off stock seat and put on single seat and cowl. There is a slight bit of paint damage on the tank where the seat had been rubbing off the tank. It is roughly about 1 inch by a 1/2 inch. Before it starts to show rust I would like to do a touch up job on it. Does anyone know of a colour match for red 98 tbs. Or if anyone wants to share any tricks for doing a good repair on small damaged areas like this.
Niall.
· Premium Member
The same has happened to mine but, since it is not visible with the seat on and becuase I don't have to worry about rust here, I haven't done anything about it.
Assuming yours is not visible with the seat mounted, why not just use a really good anti-rust paint like smooth Hammerite? You can get it in red as well.
You're from the Dublin, right? My wife is from Cabra, we go back to see her family once/twice year. Most of them are in Blanchardstown and Navan now.
Unfortunately it is slightly visible and with the wet weather I need to do a touch up job on it. Yep over in Dublin in the lashing rain at the moment so not exactly good biking weather but hopefully the summer is just around the corner somewhere. Your lucky living in a climate where you don't have to worry about rust.
· Premium Member
Well, it's not all good. Round Dallas it's all highways and arrow-straight roads - I'll use half a tank of petrol just getting somewhere with twisties. We can't lane-split (filter) here and in summer, you just fry.
But it's a real bike friendly culture, and I don't have to padlock the bike or generally worry about anyone messing with it.
Big or small, paint repair jobs are time consuming and painstaking. For such a small area, I'd be probably brush paint rather than spray and rely on various grades of wet and dry to flat it out and feather it into the surrounding paint. I've always been told, several thin layers with sanding in between applications is better than one thick layer.
So, once there's zero rust on the metal, lay on some primer, let dry and then use wet and dry, then prime again and repeat several times. Then do the same with your colour coat, getting finer and finer on the wet/ and dry. Then apply a lacquer.
There's probably some good advice on the internet somewhere with pictures and techniques. If you haven't done this before, you may want to find someone who has or practice on something less critical than the petrol tank of your pride and joy.
Good luck!
Niall:
I just painted a Viper Cafe Fairing that I installed on my '98 TBS. It's the Triumph Racing Yellow color.
I got in touch with the folks at www.paintworldinc.com, gave them the Dupont paint code, that I got from Triumph's web site, & they provided me with aerosol cans of the paint. I painted the fairing and clear-coated it & it looks great.
The paint can also be purchased in a paint stick or brush bottles and at any quantity.
You'll need to realize that it's a 2 step process. 1) paint 2) clear-coat.
Mike P.
Discussion Starter · #9 ·
Cheers lads I will check out those links. I think what I will do is just put some touch up paint on the area for the next month or so. In the summer when the weather is good I will take the tank off and do a proper job. Might pick up a free car panel in a junk yard somewhere to practice on as parrycm says you don't want to practicing on your pride and joy.
1 - 9 of 9 Posts
