I just bought an 05’ Speed Triple and after a few days of awesome days of riding, the check engine light came on. I plugged an OBDII into it and the codes P1105 and P1107 popped up. This is my first bike and I would like to fix this with some tips from you all. Is my bike still good to ride? How can I fix it?
According to my list p1105 is manifold absolute pressure sensor 1 pipe malfunction, P1107 wasn't on the list but I'm guessing it's related and could be map sensor 3 malfunction if they are in order.
Hopefully somebody will answer with more specific speed triple knowledge but I would start by checking under the tank around the throttle bodies to check for any damaged or disconnected pipes to the map sensor.
As regards riding the bike, if the light is still on after 3 heat cycles then the fault is still present and could affect the way the bike runs but it's highly unlikely to do any damage, the ECU will normally disregard any sensor values that are way out of range.
  • Like
Reactions: Migeeno
