I didn't see this topic directly 100% addressed, so apologies if its been covered fully elsewhere already...this previous thread in this forum actually shows that even the Givi cases/bags are not compatible (without mods) and shows the difference between the Triumph rack and the Givi one with two different notches...https://www.triumphrat.net/threads/givi-trekker-outback-pannier-compatibility.983094/. Dang...even less choices out-of-the-box than I thought.
Prior to seeing this forum (and that thread), I was so excited to get my new 2022 Tiger 900 that I ordered the OEM side pannier racks from the dealer without doing enough research. I only got as far in my research as realizing that Givi was the maker of the OEM Triumph racks, and saw that Givi had a "bunch" of bags that fit (also not true). Then I got the racks on the bike and realized I didn't really want Triumph (or Givi) hard cases for a few reasons that aren't that important. Even if the Givi soft cases could use these Triumph quick-connects (which now seems they can't, at least without mods), the Givi bags are expensive and maybe also not what I wanted either. I also stupidly assumed other bag manufacturers would also be putting out "compatible" clamps to fit the Triumph PL-Cam rack (or the Givi one), but that really, really doesn't appear to be the case (no pun intended). I'm also don't think Triumph makes soft bags that can use their tabbed connection (you can use them with straps, which is not what I wanted).
Deep breath, long paragraph above. Apologies.
After that realization a few months ago, I "thought" I had then found someone who was making adapter plates that could fit into the Triumph PL-cam cams (or maybe the Givi ones), but now i can't find the video nor anything online either. It's possible I made that up or was confused.
Is there anyone who is smarter than I am (lots I'm sure) and has found a solution to either adapt other brands quick-connects to these cam-style OEM racks, or know if I can take the Triumph cams off and then adapt with someone else's system? I was really hoping the SW-Motech or similar range of bags could be adapted without the obvious usage of straps, etc. I'd like to be able to take advantage of the quick-connects and take them on and off easily, and it would be awesome if I could switch between hard and soft bags as the trip needs change.
At the moment I'm wondering if I just take the racks off and go with some else's solution and new racks. Filing the Triumph rack nubs is also an option it seems, but then might only "open" the ability to use the Givi branded bags, which again I'm not sure are what I want. And does that eliminate my ability to use Triumph cases if I chose that later?
Thanks in advance for your brainpower. I should have researched this better before firing up the Triumph racks.
