1 - 3 of 3 Posts
Muffler Bearing Brass by Moto Amore
Made in the USA
This high quality brass muffler bearing replaces the stock / standard composite muffler bearing. The stock composite bearing that is between the muffler and the header pipe on your modern Vespa GT / GTS is a high wearable item. The composite bearing wears out and creates a dangerous exhaust leak.
This brass muffler bearing produced by our good friends at Moto Amore is the long term solution to the muffler bearing problem. It is easy to install and makes access to the rear wheel that much easier. This brass unit lasts much longer than the composite one, so make the smart choice and invest in one of these for your scooter.
$35
Laugh all you want, but Moto Amore makes the best synthetic blinker fluid on the planet! ;)
-Kit
1 - 3 of 3 Posts
