1 - 19 of 19 Posts
OK I'm not an electrician, how would i wire my head light and tail light now i have my magneto.i know i will need my alternator, but what the wire diagram look like. or how would i run the wires from what to what to what. if you now what i mean. sorry for the stupidity.
thanks
:-g :???:
[ This message was edited by: dgfironworks on 2006-12-10 06:22 ]
· Super Moderator
You'll have to rectify and regulate the alternator's output, so either a zener and old style rectifier, or a modern solid state regulator/rectifier.
From there, you have a hot wire. Just wire each light to receive power from each switch (on/off, hi/lo and brake light switch). Each of those switches receives power either directly from the hot wire (brake light), or through the light switch (all other).
Horn gets it's power from the horn button, which gets it's power through the keyswitch, but can also be "hot wired" if you are doing without the keyswitch altogether.
I'm not sure about these modern ARD mags, but the old ones required grounding to "kill" them, so you needed to have a keyswitch with a "normally closed" set of contacts to kill the mag when you turn the key off.
ALL components are either grounded through their mounting, or a "return" wire to the common Red wires in the harness, which are all grounded to the frame & engine.
Wire everything except for the ignition components as per stock. At the igniton switch, remove the lead that feeds the ignition coils.....the white wire, if stock. The ignition has it's own power source (a teeny alternator under the "points" cover) and you just wire it like the instructions tell you. The alternator/battery system is separate, no interaction, with the magneto ignition components.
I like the HD units. You can usually get them used from a custom shop for cheap money, as take offs. Or you can buy one of the zoomy custom ones, chrome, etc....but any of the single phase (two alternator wires) boxes from a HD will work just fine. The least alternator output is from the early evo sportsters, and at 17A, no Lucas single phase alternator will challenge it. MAP also carries the Tympanium unit, much smaller item.
· Banned
I know its an old post, but does anyone know with a magneto and sparx reg/rect how long it takes to warm up before it can power brake light and halogen head lamp?
1 - 19 of 19 Posts
