1 - 17 of 17 Posts
Just wanted to get some thoughts on what type of oil runs best through these older Triumphs. I was thinking of using Amsoil just because I know a guy and get a decent deal with it, but figured I'd ask for more opinions. I live in the southern South Carolina so it does get really hot and humid in the summer/fall months then a cool winter. Looking for something too that will help my beast stay cool too, it bothers me how hot it runs in traffic/town but it also cools down quickly too at highway speeds. Has anyone ever tried wrapping the head pipes?
I've used Amsoil for several years. It offers great protection and I think that it helps shifting. My dirt bike engine is noticeably quieter when it's hot. Read the motorcycle oil white paper on Amsoil.com for comparative testing.
Wrapping the headers isn't going to affect how hot the bike runs and I doubt that it will change the heat that you feel coming off of the bike. I'm not a fan of header wrap. I once wrapped a race car header and destroyed it, actually melted holes in it. Granted, it was extreme use, a Mazda rotary engine (exhaust temp approx. 2,000 deg) running wide open for almost 90 seconds per lap (Brainard International Raceway, no lifting from turn 10 to turn 3).
I just put in Castrol Power1 GPS, 10W40 semi synthetic. I put that in because I couldn't get my usual Motul nor anything else for that matter, we are really stuck for suppliers in this neck of the woods.
As it happens, this stuff seems really good, the transmission is silky smooth, better than with the Motul I think. I'll probably use this from now on as it is so readily available.
Roden
here's me reviving and old thread again....
But Roden, is that Castrol oil what I should be putting in my 96 Speed Triple? Gonna do an oil change on the probably next weekend, and I haven't done one before (mechanic did the last one). Just trying to find which oil I should be buying.
What you want is 10W40 or 15W50 semi- or fully-synthetic that meets the API SG spec.
-Kit
Hi,
After 15 years of ownership & tried many brands I've finally settled on
Motul 7100 10w40 Full Syn.
The gearbox shifts butter smooth now & it lasts easily to 10k as per triumph service interval.
Its expensive at approx AUD $90.00 for 4 litres but i only change the oil once a year so it's not too bad.
cheers
It's worth noting here that the Mobil 1 15W50 car oil currently on the market has been confirmed by Mobil to be the same as the old "red cap" formulation, which means its chemical makeup is probably as close as you can get now to the original Triumph/Mobil 1 15W50 bike oil. (Not that Triumph's shilling it necessarily made it better than anything else, but shill it they did!)
Me, I mix equal parts of the 15W40 Rotella-T dino oil with the 5W40 Rotella-T synthetic, but I don't have a T3 anymore so that's for my T6...
Really, it's very important that you have oil. It's almost as important that it's in the correct viscosity range, and that it doesn't have enough anti-friction additives to qualify as "EC" (Energy Conserving). Things get a whole lot less important at that point, though synthetic oils will maintain their viscosity much longer than mineral-based oils.
If you've found an oil that works well for you, there's a pretty good chance that's a good oil to use.
-Kit
Bernie, later manuals probably say JASO-MA, but my Issue 6 manual, published in March of '96, says only API/SG. It specs full-synth 5W40 for the red cam bikes (D12, Super III) and 10W40 semi for the others.
-Kit
I have used Triumph's Mobil 1 for the last ten years I have owned this bike. But, this year I tried Royal Purple fully synthetic. WOW! It shifts so much better now.
I used to be the type that was afraid to use anything but what the factory suggested. Now, I tend to be of the thought that as long as the viscosity range is correct and the things Kit said, it's good to go. Now, I suggest trying other brands in an effort to get the best performance out of your bike.
I use 20/40 Lucas synthetic in my 99 Tiger. Made mistake and used 20/50. Caused problems with clutch. Could not engage neutral and get it out of gear. When I went to 20/40 solved the problems. Good thing I read this info on this forum.
They have pretty stringent standards for being equal, but go for a full synthetic. I've preferred Amsoil for years but the esther 4T isnt available in my market. Im running royal purple at 75-80% oil change intervals now. I do a lot of red lights and the heat and humidity are harsh here so I never run the oil to the max.
1 - 17 of 17 Posts
