I've done my research here on the forum and read several cases of this issue. I purchased a pressure gauge (not cheap junk) and fittings to add to my collection of useful tools for future projects. Here is what I have observed; Cold- Idle @ 1100 rpm- 20 to 22 pounds. Rev to 2000rpm- 35 pounds. Rev above 3000 rpm-runs right up to 80 pounds.
Hot- Idle @ 1500 rpm- 6 to 8 pounds. Rev above 3000 rpm- 45 pounds is best it will read. Examining the OPRV, the spring measures 1.514 inches, book spec is 1.5312. The valve piston appears good, but the walls of the housing are scored toward the rear of the cylinder. This engine was professionally rebuilt before I bought the bike as a basket case. I replaced the timing cover and correctly installed new seals. I did not examine the oil pump. I have 325 miles on the bike and am presently running on my second oil change. I am running Penngrade SAE 40. (Please don't turn this into an oil or break in thread!) I have not thrashed the bike nor have I babied it. Some oil consumption but no smoke. One other thing that REALLY bothers me is periodically I get a baby poo slurry out of the breather when I run at highway speeds,but I think might be a build up from in town riding. (see pic)
What say you?? Thanks, HF
