I have a 04 T100. It has a small oil leak, It looks like it is coming from the small transmission cover under the front sprocket. Is this common? Can this cover just be removed and replace the gasket, or will the parts behind it move?
Absolutely the oil would dump out. Replace the gasket AFTER draining the oil.On 2007-01-05 22:11, merlin wrote:
Motley - won't the oil dump out? or is that area dry?
