After a month or so of changing gaskets, tightening bolts, and reading threads on possible sources, I finally found the oil leak (or at least one). It was coming from the nut that holds the cam chain tensioner blade. It is located on the back side of the head between the intakes(i didn't even know it existed). So, the question...
Can I simply take the nut off of the tensioner blade bolt and replace the crush washer and re-torque, or do I need to release the tension from the blade or something like that?
thanks
thanks
