1 - 9 of 9 Posts
what type of wrench do i need to change the filter on the thruxton. it's harder to get to than i thought. i purchased a cup type filter wrench from auto zone, size 65/67mm, but it keeps slipping. the next size down was too small. any suggestions? thanks.
Large channel locks worked this morning on my Bonnie. You don't need the old filter anyway, so it doesn't hurt to smash it up a bit getting it out.
Strap wrench might work. I have driven a screwdriver through one on a Ford to twist it off. It had been in place for 15 years.
Yes I agree that K & N filter will help a lot. I bought the Wal-Mart Supertech 7317 it is longer & only $2.47. If it gives me trouble I'll spend the $11 on the K&N.
So this is how it was finally acomplished. Hammered a screw driver through and twisted it off. This was the first service. Gosh, that was nasty, stinky oil! I wish I'd changed it before 500 miles.
:-D
No,you needed that green crud in there the whole 500 miles to break that engine in right.. :-D
Yeah, that stuff's basically cutting oil, so it is necessary to keep it for 500. How happy is your bike now with new oil? Mine loves it.
Smash the screw driver through it and twist off.Replace with a Ryco Z445,then you can use your auto oilfilter wrench from then on.
The ryco is the same filter just a bit larger and cheaper.
:hammer:
1 - 9 of 9 Posts
