How long does it take until the oil heats up enough for an oil change on our triples? Apologies for such a basic question, but I've scalded myself before. Thank you in advance.
What he said.I prefer to drain the oil from a warm (not hot) engine -- a procedure the Haynes manual recommends. Possibly take the bike for a short ride, park it up in your garage and give it at least 15 mins to settle as Peterh above suggests. The viscosity of the oil is such that warm oil flows out quicker than if it were stone cold -- particularly relevant in climates colder than my own
No there wont be! But unless you leaned the bike well over to the right side the previous evening there sure will be plenty of old oil sitting up on the cylinder head.How will you get more out?
I normally drain in the evening, and refill in the morning, heavier bits would go where exactly?
I've done this for year's and never had a problem, what I've also done is drop the sump to see what's there.
In a word nothing.
Sent from my GT-I9100P using Motorcycle.com Free App
Yep, that's right. Allows all the nooks and cranny's in the internal head casting to empty down through the cam shaft chain drive tunnel.So when its hot do you lean it over to the right?
My Rocket has 3 drain plugs and I level the bike before draining.
