1 - 7 of 7 Posts
I bought these and luckily have not had to "test" them. They installed easily in about 10 minutes.
what do you think of the quality? do you have both sets, forward and rear engine mount? i also noticed they come in diff diam size and cuts. do you know why? what did you choose?
thanks
I just got the rear set. Quality seems fine. Good looking considering what they are. I only saw one size when I bought mine. These things aren't jewelry to me, just something to save the bike if it gets dropped. I don't see the point in spending two or three times as much for fancy sliders with a different shape. I've seen the crash photos. They all get f*cked up when you wreck.
I installed these OES frame sliders. I chose the 2 inch angle cut units. Cut and size are merely preference. I like the fatties. Installation was easy. Quality is A++. I had a set of these on my R1 and they were tested. Results came out positive. The right side is long enough to protect the wider radiator of the 08 S3. The only complaint that I would have is that the front sliders require modification or removal of the radiator shrouds. It doesn't bother me since I was removing those at any rate. :D
Discussion Starter · #7 ·
thanks for the pics. def be purchasing soon
1 - 7 of 7 Posts
