Hey guys,
I recently replaced my header pipe. the old o2 sensor was absolutley secured in it so i went to buy a used oem sensor for the new pipe. upon installation, im getting a orange check engine light which i assume to be the computer not recognizing the new sensor and adjusting the fuel/air mapping. it’s caused a strange idle. I immediately turned it off so i could figure out what to do/what to check.should i let it idle for awhile to try and detect the new sensor? is there some tips or tricks anyone can share? is it just as simple as the sensor is broken because it was used? it was pulled off a parted out efi scrambler and appears to be the exact same sensor as my old one. I’m new to this stuff so any help is really appreciated
