1 - 7 of 7 Posts
Hi,
I'm heading into a restoration of the first bike I ever owned a 1970 T100P purchased 23 years ago & used for 7 years as my only means of transport.
I had a bash at a restoration 10 years ago & got some of the frame parts etc. stove enameled & got the head done & put standard barrels & pistons on etc. It never really got any use after that attempt & now I want to do a proper job.
I want to replace all the frame & cycle nuts & bolts. Is there anybody out there doing complete sets? There are some non original bolts which a previous owner made fit which I'd like to replace with originals.
Ideally I'm looking for a supplier who has sets of nuts & bolts for most of the parts on the bike. i.e. Battery box/oil tank, engine mounting bolts, frame bolts, mudguard bolts, various other bits & bobs.
Thanks in advance.
Click
Hi,
Many thanks for the reply.
I'm aware of many fastener suppliers, I was hoping somebody would supply a complete 'set' for my specific bike. I'm aware in Classic Car circles suppliers have packs of fasteners for particular models etc.
Failing this does anybody have a comprehensive list of fasteners required for a 1970 T100?
Once again thanks for the reply.
Click
Hi Hobbit,
Thanks for the advice, I'll update my profile now.
Many thanks for the link.
Click
It depends what you want to achieve.
I originally replaced every nut and bolt with stainless steel where I could the first time round. I have subsequently been advised to go original as that is what judges and knowledgeable restores will be looking at and that’s where some of the value is proven. That I have done it takes hours of research as all the nuts have different threads etc. What I would recommend is get all the nuts and bolts together and have them tin or cadmium plated, and then look at international suppliers for the ones you don’t have.
What I think is important is when you walk around someone else’s bike the same as yours at a show all the faults just stand out. Is this what you want to achieve?
Hi,
To be honest I'm just being lazy!!:) I just thought if a supplier already had all the fasteners I need in a kit it would save a lot of time.
I know some of the fasteners are quite specific, the ones that go into the mounting rubbers on the oil tank for instance.
Thanks for the input, now where did I put that parts catalogue!!
Click
1 - 7 of 7 Posts
