Hi all,
Thanks in advance for the help of all your knowledge!
71 650 OIF
Got the rocker boxes off currently and felt some binding/notchy type feeling in rocker movement when rotating on shaft by hand. May well be that it’s the point they go to from pushrod/valve extension and I’m rotating them past that.
i don’t think it’s shaft but rather maybe spring washer biting/binding a lil but on rocker arm face.
I don’t think it’s likely an issue givin how much pressure exerted by valve spring/pushrod, but thought it would be nice to get some nice smooth movement rather than feel the clickynness in the rotation.
Spring washers have obvious wear marked on em from rubbing metal on metal.
Got em stripped currently soaking in kero.
Can post picsif needed when I get home
thought I’d ask others findings or thoughts on the subject?? Cheers
71 650 OIF
