Hi all,
I finally got my UK registration for my new to me T140V which enabled me to get it insured.
Over the past few weeks I've fitted new Handle bar bushes, changed the headlight to a UK spec one, checked oil and tyres, adjusted the clutch push rod which helped greatly with the lever action and have been practising the technique to start her up. It was a nice sunny afternoon in the UK, 31st of March, I was really looking forward to going for the first run. I got less than 1/2 a mile from the house and we spluttered to a halt. I tickled the carbs got fuel flowing and we started again. I returned straight home, the bike died on route and I coasted onto my drive. It was obviously fuel related, I was thinking a stuck float, blocked jet or fuel tap. With a full float, the bike ran very well which was a good thing.
I'd read good reviews on the Premier version of the Amal Carbs and thought, I'd just buy a set. It turns out that I they are unavailable until at least July now., I've left my order pending. Nothing for it but to take off the carbs, strip and clean. It didn't take long to figure out where the problem was, there is a rust in the tank which is getting stopped by the fuel filters.
The reserve fuel line was full of rust, the main not so bad, but both filters were pretty badly blocked.
The Carbs were in pretty good order, but clearly have been stripped before, the floats are different colours and one of the gaskets looks home made; not a bad job was made of it though to be fair. The blockage explains why it took so long for the fuel to fill the bowls and seep over the ticklers and why it ran for a bit and then just died.
I've ordered new carb gaskets, clear fuel lines, an inline filter and new petcocks, which will arrive in a few days.
Next problem how to sort the tank out.
A quick inspection with a torch confirmed what I suspected, rust, but it wasn't as bad as it could be. Mainly on the bottom of the tank with patches all over the remainder. I've decided to attempt a rust removal exercise rather than a replacement, as a new tank is at least £500 and even then won't be as nicely painted.
I've looked at least ten You Tube Vids on how to fix this and settled on Evapo-Rust. It is probably not the best fix out there, but does the job, is safer and more eco-friendly and if it gets onto the floor won't burn a hole to Australia. I've bought 5L of the stuff, which I will add to the tank along with 70 old screws. Over the next four or five days I'll be turning the tank over regularly and wearing myself out shaking the screws around to further remove the rust.
Whilst the bike is down I've taken the wheels off and am going to have Avon Road Rider 2s fitted, the Dunlop K70's on the bike have cracks in the side wall.
It has not been all bad news though, I can't think of a better way to get to know your bike than to start taking it apart. I've never stripped an Amal before, easy when you know how.
When I'm all back up and running I'll send you picture.
