1 - 20 of 23 Posts
Hello! I recently purchased my first bike...2001 Triumph Adventurer with just shy of 17,000 miles on it.
I had the 18,000 mile service done at a dealer a few weeks ago. Afterwards I noticed a hesitation between 2,000 and 2,500 rpm. It started getting progressively worse until I was riding it home from work last Friday when a spark plug came completely out. I think it was loose from when they put the new plugs in...plus one didn't have the top cap on it...just the theaded stud so it couldn't have been making a good connection.
So...took the bike back to the dealer and they charged me to "fix the threads." I drove home from the dealer and made a stop at the store...went out to start the bike and it was DEAD. I got a jump. I made it about 5 miles through town and the bike died...battery totally dead. Had my wife come jump me and had to jump it three times to make it back up to the dealer.
The dealer tells me I have a bad battery and that it was a marine battery which was the wrong type for the bike. (The battery was supposed to have been checked out on the 18K mile service I had them do and they didn't mention it then.) AND, they said the charging system wasn't working. A couple days later they called me back and said the alternator was bad and they could replace it for $1,300! I told them I would pick the bike up...which is what I did tonight. I did keep the new battery they put in.
This is just too many coindcidences. I was fooling around with it after I got it home and noticed the instrument panel lights were out...checked the fuses, and a fuse was blown. Put a fuse in, blew again. I took the light bulbs out of the instruments because I did replace two blown bulbs with new ones that were slightly higher wattage a few weeks ago. Started the bike up and ran it for about half an hour just idling and the battery never hinted at going down...stopped it and it restarted fine. Was going to drive it around the plat a little, got on the bike, put on the brakes and the fuse blew again. This time I noticed right when the fuse blew the engine started to idle slightly faster. Another fuse in, got on the bike, brakes, blew the fuse again and again noticed the engine idle speed pick up a bit. It is a 10 amp fuse. I put a 15 in and it blew, then put a 30 in (yes I watched everything real close.). It didn't blow but it did make the main fuse blow which is also a 30 amp fuse.
SO....I'm thinking maybe the alternator isn't bad and that there is something else wrong with the wiring or another electrical component. Problem is, I don't trust my dealer to figure it out. I rode the bike with no issues for several weeks before having it "serviced."
Suggestions????
If you put on the brakes and the fuse blows I would start with that circuit, possibly a shorted wire that is raising all kinds of heck..
I'm no tech but that is where I would start. Be carful putting higher amp fuses in as that can create more of a mess.
Your Dealer
Needs doing over just like the song says. He makes a pusher look good!
Take your bike to a good Auto Electrician, bikes are generally no different from cars when it comes to fault finding and troubleshooting. They will have the necessary gear to check your charging system and various circuts.
Never, ever put a higher value fuse into a circut, especially one that is blowing fuses. You will pay big bucks at the end of the day through this practice.
The first thing I would do is check the voltage coming out of the alternator (just check the voltage across the battery terminals)
Check this voltage both at idle and higher rpm, say 4-5K rpm.
It is conceivable that the regulator in your alternator is damaged and it is putting out a LOT more than 14V.
That is speculative of course, but very odd that you have random bulbs and fuses blowing.
The running faster is also possibly explained by that - any lamps will give you some form of regulation, simply by loading the output - when those loads are no longer there, the voltage will rise even higher.
It IS possible to purchase a replacement rectifier &/or regulator for your alternator - OEM they are expensive! (still cheaper than a whole alternator)
Contact Ricks MotorSport Electrics and see if they have replacement components available for that alternator.*
ElectrexWorld in the UK does a replacement Regulator that fits most Triumphs of that type Alternator and I would imagine Rick's would also have that part.
But first just check out the voltage & see what it's doing - you can't assume that just because bike runs, all is well!
... Never, ever put a higher value fuse into a circut, especially one that is blowing fuses. ....
* I think these may be the parts - CHECK WITH THEM HOWEVER
Rectifier
Regulator
When I replaced my instrument bulbs with LEDs a few weeks ago, I also blew some fuses. The design of the base of these bulbs make for a difficult installation without mucking up the rubber socket where they go, and if the wraparound wire on the base of the bulbs gets shifted, it can create a short which will blow the fuse. Any changes which you have done to any electrical component can create a problem, and some fuses are shared by other circuits, which means seemingly unrelated problems can occur. Any good mechanic with a wiring diagram and some time can sort this out for you. Needless to say, it won't be the peckerheads who did your 18,000 mile service.
If you want to test the alternator function, just remove the positive lead from the battery while the bike is running, and see if it keeps going....
Respectfully, that can give go/no-go but not going to tell much about whether the regulator is functioning properly - it does appear that the alternator is putting out 'something', my fear is that it may be putting out too high a voltage.
What is the battery voltage when bike is not running and will it blow the fuse when you apply the brake light with only ignition on (engine not running)?
If you can blow fuses with just battery power, then need to fix whatever fundamental electrical circuit issues that are causing that.
ONLY when you have all functions working normally under battery power, then turn your attention to the alternator to see what it is imparting on the system that changes things.
Discussion Starter · #9 ·
initial findings
OK...here are my initial findings from doing some of what you all have suggested.
1. IF the 10 amp fuse (no 2 position for instrument panel, tail light) IS NOT blown and I take the positive cable off the battery while running the engine continues to run fine...at least at idle.
2. IF the 10 amp fuse IS blown and I remove the positive cable from the battery while the engine is running it immediately dies.
3. I can't seem to get the 10 amp fuse to blow with the engine NOT running.
4. With the engine running at idle I can't get the 10 amp fuse to blow...even with the repeated application of the brake.
5. When I rev the engine even briefly it blows the 10 amp fuse.
The first thing I would do is check the voltage coming out of the alternator (just check the volatge across the battery terminals)
Respectfully, that can give go/no-go but not going to tell much about whether the regulator is functioning properly - it does appear that the alternator is putting out 'something', my fear is that it may be putting out too high a voltage......
Pleeeeeaaaaase measure the voltage for me .................
Discussion Starter · #11 ·
voltage
I was in the process of checking voltages when my buddy came over to help me with all of this and went ahead and posted what I knew at that point.
Here are the results...
Voltage across the battery terminals with the engine OFF is 17v.
Voltage across the battery terminals with the engine idling is 17v.
Checking the voltage from the positive cable when it is NOT attached to the battery is about 19v idling and went up to 23 volts around 3,000-3,500 rpm.
I'm guessing all of these numbers are too high?? and that the regulator is indeed bad? I still think it is odd that the one specific 10 amp fuse is the one that always blows when there are 2 other 10 amp fuses and I don't understand why when the fuse is blown that the alternator won't charge.
....I'm guessing all of these numbers are too high?? and that the regulator is indeed bad?
Bingo!
Sorry, but your dealer was right - at least as far as the diagnosis goes, although they probably don't deal in sub-assembly repairs - even if Triumph does supply those repair components as OEM parts.
Hate to be bearer of more bad news but your new battery is probably toast now too
.... I don't understand why when the fuse is blown that the alternator won't charge.
The alternator requires a field voltage which comes in through a seperate wire (you should see a smaller gauge wire going to the alternator) - I don't have access to a specific circuit diagram for your bike, but the field connection probably comes off that same fused circuit (probably ignition circuit)
At this point you can do a couple of different things:
You can replace the regulator & hope that is all that is bad;
You can also replace the Rectifier for added insurance.
You can send the entire alternator for refurb to someplace like Ricks.
Roll the dice & buy a used alternator off EBay
I would start by calling Ricks, explain the situation & let them advise you on what options/solutions they can offer you.
P.S. Do not run your bike any futher - even for diagnostics. You run the risk of further serious damage to cirtical components like sensors & ECM.
p.p.s
Complete alternator list price is $895 - if you order from BikeBandit, use the TriumphRat discount code to get -10% which gets you to $805.
STILL a lot of money!
Best to repair the current one.
http://www.bikebandit.com/triumph-motorcycle-adventurer-2001-alternator-starter/o/m17582sch564464
Parts 17-20 are the servicable items which should make your Alternator as good as new
We know 17 (regulator) for sure is shot - the other parts might make sense while 'reconditioning' the unit.
Check the threads....there are a number of replacement alternaters (Kawasaki comes to mind), that cost much less than the Triumph ones and are bolt on replacements. You can also take a chance and check EBAY as I see them all the time. All fo the triples had the same alternater.
Oh yeah one more thing......feel free to pour brake fluid on your dealers lawn, I always was partial to Dot3.....
Discussion Starter · #17 ·
regulator
True, a new alternator looks like it would've fixed the problem but I prefer the $131 fix to the $1300 one they proposed. Since the next closest Triumph dealer is nearly 100 miles away I am making nice since I will need them for parts and supplies...ordered the regulator through them since it was the same price as bikebandits. The owners seem great...just think they have idiots in the garage.
Thanks everyone for your ideas. I'll let you know if this fixed it.
....I prefer the $131 fix to the $1300 one ....
But you wouldn't have preferred the $75 fix from Ricks? :confused:
...ordered the regulator through them since it was the same price as bikebandits.....
Actually - you can get -10% off BikeBandit parts listed price by using the TRIUMPHRAT discount code.
Discussion Starter · #19 ·
parts
Yeah, I looked at the part from Rick's. It is actually a part they get from rmstator and I haven't had good luck with that company. I'd order from bikebandits but it takes more than 2 weeks to get triumph parts from them. They say right on their site Triumph parts take 10 days but I ordered just some bolts and stuff from them more than 2 weeks ago...still hasn't shown up. Dealer will have the part this Wednesday and I will hopefully be back on the road. If I need a part and time isn't an issue I'll definitely go to bikebandits.
Agree on the delivery time from BB - that was more an fyi for future.
Certainly not intended as argumentative, but my experience of Rick's customer support has been outstanding, and their components excellent - my Stator came from them.
Rick's has a 12mo warranty on all their parts with exception of CDI so you have some security/insurance there also (that you won't get with Triumph part)
How did you determine the Rick's part is same as the RMStator (although I don't doubt that it is!) - there is little info about it, not even a pic on their site.
I'm not sure that RMStator is the manufacturer of that Regulator anyway - just sell the same part as many others:
http://www.rmstator.com/en/motorcyc...nso/nippon_denso_for__900_thuderbird/4464.htm
Electrosport also sells same part and I normally wouldn't touch their products with a 10' pole.
http://www.electrosport.com/products/product-detail-557.php
And the one from Electrexworld appears to be same one again.
http://www.electrexworld.co.uk/rg25...uki-yamaha-triumph-zx-gpz-gsx-gtr-1319-0.html
Its all moot as you have the Triumph one coming anyway of course.
Here's hoping you get everything resolved and also hope your new battery has no lasting issues from the overcharge.
1 - 20 of 23 Posts
