Personally………………I am not a fan of rubber foot pegs with their clunky style and vague, disconnected feel.
So after installing the NHs I decided to personalize with a set of Emgo 50-11211 Honda pegs ($25). With just a bit of filing off of the inside edge, the pegs are a perfect fit.
These pegs will also lower your foot placement by ¾ inch, and for my taste was an added bonus.
A bit more refinement...... as I cut off 1/2 inch of the outer portion of the brake peddle as this ensures my boot does not touch the pedal while moving around on the pegs. Also the black, plastic bits to cover the open hole on the end of the pegs.
A bit more refinement...... as I cut off 1/2 inch of the outer portion of the brake peddle as this ensures my boot does not touch the pedal while moving around on the pegs. ..
Nice work Dale. I may have to get after my Hyde's and follow suit. I've never "fabricated" anything before though...We may be neighbor's soon. The wife and I are looking at palces in Carlsbad as we speak.
Thos rearsets lookk great!
Huh. I guess that's another difference between the Bonnie Hydes and the Scrambler Hydes.
Mine (the Scrambler version) came with decent knurled aluminum flip-up pegs very similar to the ones you now have. I would include a picture, but it is cold and dark outside, so girls and beer are about the only two things that'll get me out of my apartment at the moment.
Of course, mine also took a lot of filing, cutting, shimming, and otherwise fine-tuning to fit correctly in the first place. Not sure who calculated the spacing, but almost everything was off by a millimeter or two. Probably the most effort I've had to put into a "bolt on", but whatever... totally worth the work.
Hey Dale, I know this post is dated. I have these NH rearsets and was wondering a few things.
I didn't install them myself, they came installed on the bonneville. Looking at your pictures it appears as though the angle of both the shift and the brake lever are much more extremem than mine. Wondering if there was room to adjust as I'd like for the brake lever especially to be angled a bit more downward to avoid my foot from resting too hard on it.
I think I may also install those pegs as the rubber has completely fallen off my left side. All I need is a bit of filing?
So I have noticed my Scrambler 900 carbie has been starting but required a little cranking before it fired up.
Sometimes there was a bit of a bang as it fired up. Ok a big bang!
All the excess fuel was burnt off I guess.
Been looking and checking things but have not identified anything.
Today...
I wasn't going to post this but then I saw how much a new brake disc costs and thought if someone else gets into the same predicament, they may be able to save a bit of money.
I suppose it depends on how bent the disc is, mine was about .030" (.76mm) in one spot
I would be interested to know...
Anybody tried it?
The intake port floors seem really low. It's almost like the head came from the factory with a crap porting job. That forces a really sharp turn on the short side just above the valve seats. I took off the edge, but radiusing it any further would effectively flatten the...
Hello all! It´s a shot in the dark but given the knowledgeable people in this forum I hope someone can shed some light on my problem!
So a few days ago I had the misfortune of someone stealing my ECU from my bike while it was parked in a garage! He was kind enough not to cut or strip or make a...
A forum community dedicated to Triumph Motorcycle owners and enthusiasts. Come join the discussion about performance, racing, cafe racers, bobbers, riding, modifications, troubleshooting, maintenance, and more!
