1 - 11 of 11 Posts
This might be completely normal, but when I'm walking the bonnie (engine off) in an enclosed space, like a garage, I hear a subtle sound, like it's the wheels making a noise while turning. Almost sounds like a very soft, metal on metal sound. Doesn't sound bad, I would just expect it to be completely silent.
Any thoughts? Should I have it looked at, or is this normal?
Thanks!
Mine does it, so did my ZX-11. I think it is very slight break drag. On the center stand adjusting the chain & turning the wheel by hand I've heard it. Dealer of both the ZX-11 & T-100 say it is "normal"...
Chances are the noise is your disk brakes rubbing on the rotor. If that's it, then its normal and you don't have to worry.
Disk brakes are always in contact with the rotor's, hence the noise, like something is dragging.
I had over 15,000 miles on my ZX-11, & put 6,400 miles on 8 months of ownership of the T-100, & haven't had a brake rotor problem with either, so I dunno... I've never really worried about it. :???:
excellent. I was just being paranoid. I wonder how many thousands of dollars this forum has saved people who were worrying needlessly!
Not nearly as many as it has caused people who formerly thought their bikes were just fine to spend...
Phew, All along I thought the squeek was a mouse in my basement :hammer: :-D
My rear disk rubs lightly on the brake pad(s) when I turn the rear wheel manually. I don't worry about it, just check the pad and the rotor for wear.
1 - 11 of 11 Posts
