Hi everyone first off i am new the forum and have read a lot of no start sprint write ups and no one has the exact problem i have i think...maybe wrong. So i got this triumph on a trade for my bobber i built and it ran great when i got it, however it was red and yellow painted by an art student....who couldnt paint apparently. So i removed the tank to paint and the side panels. when i removed i checked plugs are new he said he changed them. checked all the vacuum hoses and found two broken at the air idle valve(assume thats the name for piece that has the three vacuum hoses and goes inside the airbox when its fitted). replaced both hoses one going to cylinder 3 an one going elsewhere forget exact end. Other than that i did nothing. after painting bike i reassembled everything. fuel hose on left to lower point on tank right tube hose to upper straight connector. check valve vacuum tube to forward hole on tank and drain off tube to back hole. reconnected fuel level sensor and reconnected pump. turned key turned kill switch to on heard pump prime primed it a few times to fill the lines....pulled clutch in hit starter....starter cranked no start..... did this several times then put battery on charger to not draw to much while trying to start.....stillll no start......where did i go wrong or forget to do?
