1 - 3 of 3 Posts
Hi everyone and thanks for help in advance,
I have a 2008 triumph sprint st 1050, which was working fine when I put it away for the winter. Now she's back out again I can't get any life out of her.
The headlights are working and there's clicking sounds coming from inside the bike when I turn the key, but nothing on the dash or dials. And nothing when trying to start as normal.
I've tried charging the battery (it did seem a bit flat, judging by the headlights), put a brand new battery in. I've checked and swapped around the fuses (under seat and side compartment), and checked the relays.
Nothing has made a difference, so any help is appreciated, especially as a garage is out of the question currently and I have loads of time.
Thank you!
Laurie
I've taken the kill switch apart and checked all connections, but it seems ok. Also if I turn the key to ignition with kill switch set to off, wait for the alarm to set and then flick it to on, the alarm goes off straight away.
To me this suggests that both ignition and kill switches are working???
Any other ideas?
1 - 3 of 3 Posts
