1 - 2 of 2 Posts
First I love my 97 t595! Hate her not running! I seam to have a lack of good spark. Have replaced plugs, ohm'd the primary and secondary sides of the coil on plugs. Have read that the cam sensor can go bad or if the air gap is off this can cause problems. Have the cam cover off but it is not readily obvious how to check and or adjust the gap? Any in site would be appreciated!
Administrator
Welcome to the forum!
I am also a big fan of the Daytona models from the '90s. I had a 1999 1200 SE myself, miss it big time! Please share photos of your Triumph when you can.
The Daytona Deliberations forum is where you will find the folks with the knowledge and experience to assist you. Intorduce yourself and repost your question in there. You can also search the existing threads using the "search this forum" button up to the right.
http://www.triumphrat.net/daytona-deliberations/
Best of luck getting your T595 sorted! We are happy to have you.
Cheers!
1 - 2 of 2 Posts
