G
Guest
·Just purchased a 1050 (1st March) and have to say that I am very pleased with the bike. About 700 miles on the clock and building the revs up in line with the recommendations - no point in doing anything else really !!
I've read all about the grabby clutch and notchy gearbox, but it's not anywhere near as bad as some of the press make out, and the gearbox should improve through time.
Only observation (sic) I would make is the suspension seemed to be a bit hard on what should have been on factory settings (16 clicks out) when checked the screw was fully in - no bloody wonder it was a firmer than expected ride!!
Not good from Triumph or dealer
(if this is part of the PDI).
Checked all the other settings and they were all as should be. Proves it's worth double checking the settings before setting off, and not just assuming because it's new it will be set as standard.
Anyhow since playing around with the settings the bike is sorted and a lot more comfortable than it was !!
Bike stomps along tho' and in high winds it doesn't get as much buffeting as I would have thought. Handles really well in all aspect - and is firmly planted when committed through corners. Cannot wait for more than the one dry day I've had it out............
Out in the cold and wet I dropped a gear to overtake a couple of cars and ended up with the rear wheels spinning and stepping out slightly, no real drama - but the Tiger does not need as many gearchanges as other bikes I've ridden due to the torquey motor. Part of the learning curve with a new bike!
I bought the ABS model (extras being centre stand alarm & heated grips - must be getting old man syndrome!) and when practicing with it's stopping power, I have to say I am very impressed with the anchors - really hard braking before ABS kicks in - well done Triumph
That's about it - stomping bike, handles well, is sure footed, loads of torque, comfy seat, warm hands in the cold..........what else is needed to increase the grin factor?
[ This message was edited by: Fiferat on 2007-03-09 10:32 ]
